#IBMPureSystems devops cloud Optimizing and assuring availability of applications is critical to the success of any application architecture
This week IBM announced its next-generation platform, IBM PureSystems. IBM PureSystems comprise a fully integrated set of solutions that is managed through a single interface, providing a faster time to value by reducing system configuration time and simplifying system administration tasks.
It’s kind of like IBM’s version of devops in a box.
But like most integrated compute, network, and storage systems today designed for rapid provisioning and simplified management in what are the increasingly complex interconnected systems making up cloud computing, it needed a little something to make it even better: application delivery.
That’s where F5 comes in.
F5 brings its application delivery expertise to IBM PureSystems through a hybrid application delivery network (ADN) comprised of both virtual and hardware-hosted application delivery services. Together, F5 & IBM provide an integrated computing solution for consolidating IT by increasing application availability, adding security and efficiency of virtualized servers, storage and networks with unified management for application delivery for the enterprise and to the cloud.
F5 Solutions: F5 BIG-IP LTM VE running on VMware on the IBM PureFlex System and BIG-IP product line front ending IBM PureFlex Systems to provide offload, optimization, disaster recovery and security.
In testing scenarios, both BIG-IP hardware and virtualized platforms enhance the service quality of IBM PureSystems and provide a high availability environment for an enterprise-class application — in this case IBM WebSphere® Application Server. Using both the hardware and virtual editions of BIG-IP products provide certain advantages in large environments:
· Hardware-based platforms can offload the IBM PureFlex Systems’ server node’s high-processor utilization tasks, such as encryption, compression, and increasing virtual machine (VM) density. It can also be used as a frontline defense from distributed denial of service and other attacks before they reach the application environment.
· The usage of the virtualized edition for individual applications, customers, or lines of business can provide greater control, granularity, and elasticity. Additional modules can then augment standard high availability, optimization, and security scenarios with single-sign on capability, application firewalling, web acceleration, and wide area network (WAN) optimization.
· Hardware and software work in tandem to create a single, unified platform for application delivery, high availability, optimization, and control for IBM PureSystems environments.
For example, the addition of F5 BIG-IP services to the IBM PureSystems architecture allowed the system to handle failures at all layers – whether it was the IBM PureFlex Systems’ node or the application server, whether it was a virtual instance of BIG-IP VE or the active physical BIG-IP LTM. Regardless of where the failure occurred, the systems dynamically compensate for failure and assure the highest availability possible within and across the systems.
The advantages of deploying both hardware and virtual editions of BIG-IP products with IBM PureSystems include:
- Offload encryption and compression onto hardware-based platforms to increase virtual machine (VM) density and improve performance.
- Improve front-line security to defeat attacks before they reach the application environment.
- Enhance control, granularity, and elasticity with a virtualized Application Delivery Controller (ADC) for individual applications, customers, or lines of business.
Further enhancements include software modules providing single sign on capability, application firewalls, web acceleration, and WAN optimization. Hardware, virtual editions, and software work in tandem to deliver a unified, high-availability platform for application delivery, optimization, and control in IBM PureSystems environments.
Additional Resources:
F5 and IBM PureSystems: A Foundation for the Next Generation Data Center
F5 Solutions for IBM applications
Bursting to the IBM SmartCloud
F5 and IBM’s Dynamic Infrastructure Strategy
IBM and F5 — Extending data center networks to the cloud
- F5 Friday: Addressing the Unintended Consequences of Cloud
- F5 Friday: HP Cloud Maps Help Navigate Server Flexing with BIG-IP
- F5 Friday: Enhancing FlexPod with F5
- The Conspecific Hybrid Cloud
- The Three Axioms of Application Delivery
- At the Intersection of Cloud and Control…
- The Pythagorean Theorem of Operational Risk
