F5 External IP
Can someone please assist , Im trying to assign external ip address on the f5 ver 11.4 after changing ip address i dont see the space to type default gateway address.. and unable to ping ip address externl
You can configure the default gateway in Network >> Routes.
Destination and mask must be set to 0.0.0.0
(tmos) net
(tmos.net) create route DEFAULT  network default
DEFAULT is the name of the route. You can set it to anything else you may want.
GUI:
Network  ››  Routes
Destination: 0.0.0.0 Netmask: 0.0.0.0 Resource: Use Gateway Gateway Addressshould be the gateway you want.
Hi Yann thanks for the asnwer, I have configure the default gateway , but still not working see below: Name external_default_gateway Partition / Path Common Description Destination 0.0.0.0 Netmask 0.0.0.0 Resource Gateway Address MTU
Here the tmsh configuration for a default gateway :
net route Default_Gateway {
    gw x.x.x.x
    network default
    gw x.x.x.x
    network default
I think that you may have routing issue outside the F5 system
thanks everyone , I manage to troubleshoot problem was on the IP range ,New ip address I wanted to use was out of the range with one on the switch , apologize
