Hello Guys,
Hope you all are doing well.
I am provisioing a standalone F5 in azure using declarative onboarding. I was able to configure most of the parameters using the json declaration, but I was not able to find a configuration for the following 2,
01 - for gui security banner text configuration
02 - management security firewall configuration to mitigate the api access vulnerablilty.
If any of you were able to find a config for the above 2 scenarios, would you be kind enough to share it with me.
