F5 DNS Wide IP and Express Questions
Hi everyone,
I’m looking for clarification on a couple of things related to the F5 DNS and Listener, and a monitoring question.
  1. Simple question, if I have an FQDN (Wide IP) configured, but disabled, how does the DNS Listener handle such queries? Would the F5 simply move on to DNS Express for an answer in such a situation where the matching Wide IP is disabled on the GTM/DNS?
  2. I’m curious as to how the F5 DNS handles queries which have matching zone records for the primary domain, but not the sub domain. For example, if I have a zone recorded created only for dev.f5.com and a DNS query is sent to the F5 for labs.dev.f5.com, would the F5 find a match and respond from the dev.f5.com zone record?
  3. May I know what the best method is (which doesn’t require configuration changes) to monitor and track queries and responses sent to and from the F5. For eg, if I send a DNS query to the F5 for name resolution and load balancing, I would like to know how the F5 DNS handled such a request in detail (how it determined the resolution at the DNS and Load Balancing levels)
Thank you!
1) Simple question, if I have an FQDN (Wide IP) configured, but disabled, how does the DNS Listener handle such queries? Would the F5 simply move on to DNS Express for an answer in such a situation where the matching Wide IP is disabled on the GTM/DNS?
ANS: Yes, BigIP will simply move on to DNS Express.
Refer to to “DNS request order of operation for BIG-IP systems” section of myF5
2) I’m curious as to how the F5 DNS handles queries which have matching zone records for the primary domain, but not the sub domain. For example, if I have a zone recorded created only for dev.f5.com and a DNS query is sent to the F5 for labs.dev.f5.com, would the F5 find a match and respond from the dev.f5.com zone record?
ANS: Request is handled as per “Unhandled Query Actions” setting.Following article explains quite well.
K14510: Overview of DNS query processing on BIG-IP systems
3) May I know what the best method is (which doesn’t require configuration changes) to monitor and track queries and responses sent to and from the F5. For eg, if I send a DNS query to the F5 for name resolution and load balancing, I would like to know how the F5 DNS handled such a request in detail (how it determined the resolution at the DNS and Load Balancing levels)
ANS::
K25751652: How to configure Decision Logging for the F5 BIG-IP DNS/GTM to local log directory
K65762138: Configuring BIG-IP DNS to log dns queries and responses
Hope this is helpful.
Regards,
Nag
This depends on the resolution options set in the DNS profile on the listener - this defines the resolution steps taken by the BigIP to resolve the name. If you have DNS Express enabled in the DNS profile, then yes - that will be the next resolution step.
Yes - that is basically how DNS glue records work. But responses from dev.f5.com for hosts in labs.dev.f5.com will not be authoritative.
Remember - this is just descending to bind - so the behaviour is as per bind.
K14615: Configuring the BIG-IP DNS system to log wide IP request information
