F5 Deployment Guide for Exchange Server 2010 updated - v3.0
Short link to the new guide: http://tinyurl.com/exchdg
- Substantially updated the configuration for Edge Gateway and APM
- Updated manual configuration tables in the appendix
- Modified timeout value for RPC Client Access persitence from 3600 to 7200 seconds.
- Added Appendix B: Technical Notes with detailed descriptions of Slow Ramp Time, SAN SSL certificates and Outlook Client configuration.
- Added updated iRules for persistence
Get it here: http://www.f5.com/pdf/deployment-gu…010-dg.pdf
Thanks!
James Hendergart
Sr Business Development Manager
F5 Networks
First of all, a big thank you for the continued development of this deployment guide. It serves as an excellent reference.
I have a few concerns I’d like to mention.
The “Microsoft-Server-ActiveSync” value will never be hit because of the lowercase conversion here:
switch -glob -- [string tolower [HTTP::path]] {
“/Microsoft-Server-ActiveSync” {
Also, why are “/ews*” and “/oab*” in the iRule but no explicit reference to “/owa*”?
Finally, my pcaps include many calls to “/autodiscover/autodiscover.xml” which is not in the iRule and none to “/xml/autodiscover.aspx” which is.
- Jeli
hi Jeli, I believe there’s no reference to /owa because it should fall through to the default case at the bottom of the rule.
About the autodiscover URI and lowercase conversion-we will check the configuration and make adjustments as necessary. Thanks for your input on this.
Mike
