In F5 4200v with TMOS 11.4.0, can somebody explain the cron jobs that are running and what each cron job does? Any documentation will be very useful.
[root@ktc1aaaslb01:Active:In Sync] etc ls -ltr cron* -rw-r--r-- 1 root root 253 May 17 2013 crontab -rw-r--r-- 1 root root 176 May 17 2013 cron.usbflush -rw-r--r-- 1 root root 69 Aug 26 09:44 cron.system_check -rw-r--r-- 1 root root 0 Oct 8 19:43 cron.deny
cron.monthly: total 0
cron.weekly: total 6 -rwx------ 1 root root 319 May 17 2013 rpm -rwx------ 1 root root 577 May 17 2013 makewhatis.cron -rwx------ 1 root root 133 May 17 2013 5checkcert
cron.d: total 2 -rw-r--r-- 1 root root 87 May 17 2013 sysstat
cron.daily: total 9 -rwx------ 1 root root 2291 May 17 2013 logrotate -rwx------ 1 root root 312 May 17 2013 tmpwatch lrwxrwxrwx 1 root root 32 Oct 8 19:43 pendsect → ../../usr/libexec/smart_parse.pl lrwxrwxrwx 1 root root 36 Oct 8 19:46 update_dpi_sigfile → /usr/share/ts/bin/update_dpi_sigfile lrwxrwxrwx 1 root root 36 Oct 8 19:46 asm_update_sigfile → /usr/share/ts/bin/asm_update_sigfile
cron.hourly: total 19 -rwx------ 1 root root 348 May 17 2013 pwdcheck -rwx------ 1 root root 1706 Aug 26 09:18 genkeys-1024 -rwx------ 1 root root 692 Aug 26 09:18 genkeys -rwxr-xr-x 1 root root 65 Aug 26 09:26 avr_run_scheduled_reports lrwxrwxrwx 1 root root 32 Oct 8 19:42 avr_logrotate → /usr/share/avr/bin/avr_logrotate lrwxrwxrwx 1 root root 32 Oct 8 19:43 cbr_logrotate → /usr/share/cbr/bin/cbr_logrotate lrwxrwxrwx 1 root root 38 Oct 8 19:43 iprepd_logrotate → /usr/share/iprepd/bin/iprepd_logrotate lrwxrwxrwx 1 root root 36 Oct 8 19:46 purge_mysql_logs.pl → /usr/share/mysql/purge_mysql_logs.pl lrwxrwxrwx 1 root root 37 Oct 8 19:46 dosl7d_logrotate → /usr/share/dosl7/bin/dosl7d_logrotate lrwxrwxrwx 1 root root 30 Oct 8 19:46 send_sync.pl → /usr/share/ts/bin/send_sync.pl lrwxrwxrwx 1 root root 31 Oct 8 19:46 save_cores.pl → /usr/share/ts/bin/save_cores.pl lrwxrwxrwx 1 root root 28 Oct 8 19:46 cleanup.pl → /usr/share/ts/bin/cleanup.pl lrwxrwxrwx 1 root root 31 Oct 8 19:46 asm_logrotate → /usr/share/ts/bin/asm_logrotate lrwxrwxrwx 1 root root 34 Oct 8 19:46 wa_logrotate → /usr/local/wa/scripts/wa_logrotate
