f5.citrix_vdiv1.1.0rc6 Receiver 4.1 Problems
Hi!
I have deployed iApp f5.citrix_vdiv1.1.0rc6 to pubblish Citrix Storefront 2.1. I have tried to use Webtop and Storefront portal direclty, but without success.
My problem is that I can’t use Citix Receiver 4.1 because it can’t connect to my public https:// site.
Are there some particular configuration to do?
Mauro Mauro
What version of TMOS are you running?
Version 11.4.1
Version 11.4.1
Have you upgraded to 11.4.1 HF3? That is the right version to be using with Receiver 4.1. Also probably worth opening a support case if you are completely stuck getting things to work. Did you read the associated deployment guide?
I have read the deployment guide. Now I can connect Receiver 4.1 using webtop. With this configuration I can’t use Storefront service (favourite applications). My version is 11.4.1 HF2, but I have just installed HF3. Tonighit I’ll reboot the machine. Is this the solution of my issue in your experience/opinion?
I have update to 11.4.1 HF3, but the situation didn’t change…
