Having a few difficulties upgrading a BIG-IP 3400 from 9.4.8 to any version 10.x image.
The following are the versions I’ve tried:
10.1.0.3341.0 10.2.2.763.3 10.2.3.112.0 10.2.4.577.0
To upgrade I’m running the following command:
image2disk --format=volumes BIGIP-10.1.0.3341.0.iso
Obviously replacing the version number with the relevant image I’m trying to upgrade to each time.
The F5 reboots, and starts copying packages however after 30 seconds or so just stops copying. The cursor in the console is still flashing but no matter how long it’s left, the package doesn’t copy. It seems to be a different package with each version/image (but always the same package per version) at point of freezing, which I’m guessing is suggesting a space issue? I’ve checked free space on the device and it has over 2GB free at root which should surely be enough?
If anyone has any advice or pointers, it would be kindly appreciated.
Thank you
