F5 BigIP LTM VE and OpenStack LBaaS integratation
I have followed various bits of documentation from F5 on how to get the LBaaS agent and driver installed and configured in OpenStack. However, when I try to add a pool, I get the error message:
“No eligible backend for pool pool_id”
and in the logs:
“No active lbaas agents for pool pool_id”
The neutron lbaas agent doesn’t show up in the output of ‘neutron agent-list’, even though it is installed.
I am running this on a multi-host DevStack build running Icehouse and the F5 LTM VE pair are running BIG-IP 11.5.1 Build 4.0.128 Hotfix HF4. They are correctly configured as a HA pair.
Additional log file info, from the F5 agent log: 2014-10-02 23:30:38.197 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf 2014-10-02 23:30:38.197 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 from (pid=19679) __init__ /opt/stack/neutron/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93 2014-10-02 23:30:38.232 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver [-] physical_network default = interface 1.1, tagged False from (pid=19679) __init__ /opt/stack/neutron/neutron/services/loadbalancer/drivers/f5/bigip/icontrol_driver.py:278 2014-10-02 23:30:38.232 INFO neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver [-] Opening iControl connections to lbaas-adm @ bigipeagcloudqa2.int.thomsonreuters.com 2014-10-02 23:30:38.939 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver [-] DEBUGG1 None from (pid=19679) _init_connection /opt/stack/neutron/neutron/services/loadbalancer/drivers/f5/bigip/icontrol_driver.py:3012 2014-10-02 23:30:38.939 ERROR neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver [-] Could not communicate with all iControl devices: device bigipeagcloudqa2.int.thomsonreuters.com BIG-IP not provisioned for management LARGE. extramb=0 2014-10-02 23:30:38.940 INFO neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver [-] iControlDriver initialized to 0 hosts with username:lbaas-adm 2014-10-02 23:30:38.940 INFO neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver [-] iControlDriver dynamic agent configurations:{‘tunnel_types’: [‘vxlan’, ‘gre’], ‘bridge_mappings’: {‘default’: ‘1.1’}} 2014-10-02 23:30:38.940 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] DEBUGG None from (pid=19679) __init__ /opt/stack/neutron/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:168 2014-10-02 23:30:38.940 ERROR neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Agent host attribute is not configured by the driver. Fix the driver config and restart the agent. 2014-10-02 23:30:38.947 DEBUG neutron.openstack.common.service [-] f5_bigip_lbaas_device_driver = neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver.iControlDriver from (pid=19679) log_opt_values /usr/lib/python2.7/dist-packages/oslo/config/cfg.py:1941 2014-10-02 23:30:38.948 DEBUG neutron.openstack.common.service [-] f5_loadbalancer_pool_scheduler_driver = neutron.services.loadbalancer.drivers.f5.agent_scheduler.TenantScheduler from (pid=19679) log_opt_values /usr/lib/python2.7/dist-packages/oslo/config/cfg.py:1941 2014-10-02 23:30:38.963 DEBUG neutron.openstack.common.service [-] service_providers.service_provider = [‘LOADBALANCER:F5:neutron.services.loadbalancer.drivers.f5.plugin_driver.F5PluginDriver:default’, ‘VPN:openswan:neutron.services.vpn.service_drivers.ipsec.IPsecVPNDriver:default’] from (pid=19679) log_opt_values /usr/lib/python2.7/dist-packages/oslo/config/cfg.py:1949
Hi Michael,
Can you open a case with F5 Support on this?
Thanks, Aaron
Hi Aaron,
Thanks for the response, but I have already raised a support case (reference: 1-671237432) and was told that the plugin wasn’t supported and I’d have to post to DevCentral to get a response…
Any help would be very appreciated.
Regards, Michael
It turns out that the key error message here was:
The following can be done to rectify this, perform either:
1) Under resource provisioning (in the UI) change Management (MGMT) to ‘Large’ 2) Run ‘tmsh modify sys db provision.extramb value 500’ (from the advanced shell not tmos)
It seems that performing both steps allows the plugin to work as well. Hope this helps someone else
Hi All, I got this error when I start f5-agent: I got this error when I am trying to start the agent:
2015-01-07 12:10:59.712 42967 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2015-01-07 12:10:59.714 42967 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 __init__ /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
Error importing loadbalancer device driver: neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver.iControlDriver
I run 3 nodes in my vmware workstation: one controller, one compute and one network node I installed the driver in controller node, and installed both agent and driver in network node. Then follow the readme file which in the downloaded file.
I can see “f5” in horizon when I add pool in the Load balancer. Of course, it will be failed as f5-agent is not running.. below is my f5-agent ini file. Anybody can help me?
here is my f5-agent conf:
root@network:/etc/neutron egrep -v "^|^$" f5-bigip-lbaas-agent.ini
[DEFAULT]
debug = True
periodic_interval = 10
f5_static_agent_configuration_data = name1:value1, name1:value2, name3:value3
f5_device_type = external
f5_ha_type = standalone
sync_mode = replication
f5_external_physical_mappings = default:1.3:True
f5_vtep_folder = 'Common'
f5_vtep_selfip_name = 'vtep'
advertised_tunnel_types = gre
l2_population = True
f5_global_routed_mode = False
use_namespaces = True
f5_route_domain_strictness = False
f5_snat_mode = True
f5_snat_addresses_per_subnet = 1
f5_common_external_networks = True
icontrol_hostname = 192.168.232.245
icontrol_username = admin
icontrol_password = admin
icontrol_connection_retry_interval = 10
here is my neutron.conf, and there is haproxy setting, it works in my openstack.
root@controller:/home/mycisco egrep -v "^|^$" /etc/neutron/neutron.conf
[DEFAULT]
state_path = /var/lib/neutron
lock_path = $state_path/lock
core_plugin = ml2
service_plugins = router,lbaas
auth_strategy = keystone
allow_overlapping_ips = True
rabbit_host = 192.168.232.138
rpc_backend = neutron.openstack.common.rpc.impl_kombu
notification_driver = neutron.openstack.common.notifier.rpc_notifier
notify_nova_on_port_status_changes = True
notify_nova_on_port_data_changes = True
nova_url = http://192.168.232.138:8774/v2
nova_admin_username = nova
nova_admin_tenant_id = f0ef0312929d433b9b1dcc3d030d0634
nova_admin_password = service_pass
nova_admin_auth_url = http://192.168.232.138:35357/v2.0
[quotas]
[agent]
root_helper = sudo /usr/bin/neutron-rootwrap /etc/neutron/rootwrap.conf
[keystone_authtoken]
auth_host = 192.168.232.138
auth_port = 35357
auth_protocol = http
admin_tenant_name = service
admin_user = neutron
signing_dir = $state_path/keystone-signing
[database]
connection = mysql://neutron:NEUTRON_DBPASS@192.168.232.138/neutron
[service_providers]
service_provider=LOADBALANCER:Haproxy:neutron.services.loadbalancer.drivers.haproxy.plugin_driver.HaproxyOnHostPluginDriver:default
service_provider=LOADBALANCER:F5:neutron.services.loadbalancer.drivers.f5.plugin_driver.F5PluginDriver
service_provider=VPN:openswan:neutron.services.vpn.service_drivers.ipsec.IPsecVPNDriver:default
[DEFAULT]
debug = True
f5_snat_mode = True
[DEFAULT]
core_plugin = ml2
[quotas]
[agent]
auth_port = 35357
[database]
[service_providers]
ubuntu 14.04, icehouse. Install manually by apt. Does the agent support this ?
