F5 BigIP APM VPN some LDAP field are base64 encoded
We have F5 BigIP APM (16.1.5.2) for VPN SSL and for some user some LDAP field are base64 encoded (because of french accent).
I have try in Variable Assignement :
session.ldap.last.attr.displayName =
set encoded [mcget {session.ldap.last.attr.displayName}]
set decoded [b64decode $encoded]
return $decoded
But in log
2025-04-17 19:06:54 x.x.x.x - err apmd[1069]: 01490086:3: /Common/AP:Common:77c07d2d: Rule evaluation failed with error: invalid command name “b64decode”
Is it possible to have the good syntax for this conversion ?
Thank you
So i have done in Variable Assign :
session.ldap.last.attr.displayName = mcget -decode {session.ldap.last.attr.displayName}
SOLVED
