My f5 device auto reboot .the messages view as below.who can help me? thanks.
/var/log/messages
Oct 28 04:02:01 BIGIP1500 syslog-ng[234]: new configuration initialized
Oct 28 17:08:36 BIGIP1500 syslog-ng[236]: syslog-ng version 1.6.5 starting
Oct 28 17:08:36 BIGIP1500 Linux version 2.4.21-9.1.2.37.0smp (root@eeyore.f5net.com) (gcc version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)) 2 SMP Tue Apr 25 15:38:38
PDT 2006
Oct 28 17:08:36 BIGIP1500 BIOS-e820: 0000000000000000 - 0000000000098000 (usable)
Oct 28 17:08:36 BIGIP1500 BIOS-e820: 0000000000098000 - 00000000000a0000 (reserved)
Oct 28 17:08:36 BIGIP1500 BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Oct 28 17:08:36 BIGIP1500 BIOS-e820: 0000000000100000 - 000000002fff0000 (usable)
Oct 28 17:08:36 BIGIP1500 BIOS-e820: 000000002fff0000 - 000000002fff3000 (ACPI NVS)
Oct 28 17:08:36 BIGIP1500 BIOS-e820: 000000002fff3000 - 0000000030000000 (ACPI data)
Oct 28 17:08:36 BIGIP1500 BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Oct 28 17:08:36 BIGIP1500 user: 0000000000000000 - 0000000000098000 (usable)
Oct 28 17:08:36 BIGIP1500 user: 0000000000098000 - 00000000000a0000 (reserved)
Oct 28 17:08:36 BIGIP1500 user: 00000000000f0000 - 0000000000100000 (reserved)
Oct 28 17:08:36 BIGIP1500 user: 0000000000100000 - 000000000e000000 (usable)
Oct 28 17:08:36 BIGIP1500 0MB HIGHMEM available.
Oct 28 17:08:36 BIGIP1500 224MB LOWMEM available.
Oct 28 17:08:36 BIGIP1500 found SMP MP-table at 000f5700
Oct 28 17:08:36 BIGIP1500 hm, page 000f5000 reserved twice.
Oct 28 17:08:36 BIGIP1500 hm, page 000f6000 reserved twice.
Oct 28 17:08:36 BIGIP1500 hm, page 000f1000 reserved twice.
Oct 28 17:08:36 BIGIP1500 hm, page 000f2000 reserved twice.
Oct 28 17:08:36 BIGIP1500 NX protection not present; using segment protection
Oct 28 17:08:36 BIGIP1500 On node 0 totalpages: 57344
Oct 28 17:08:36 BIGIP1500 zone(0): 4096 pages.
Oct 28 17:08:36 BIGIP1500 zone(1): 53248 pages.
Oct 28 17:08:36 BIGIP1500 zone(2): 0 pages.
Oct 28 17:08:36 BIGIP1500 __va_range(0x2fff3000, 0x28): idx=33 mapped at fffdd000
Oct 28 17:08:36 BIGIP1500 __va_range(0x2fff3040, 0x24): idx=33 mapped at fffdd000
Oct 28 17:08:36 BIGIP1500 __va_range(0x2fff3040, 0x74): idx=33 mapped at fffdd000
Oct 28 17:08:36 BIGIP1500 __va_range(0x2fff7240, 0x24): idx=33 mapped at fffdd000
Oct 28 17:08:36 BIGIP1500 __va_range(0x2fff7240, 0x74): idx=33 mapped at fffdd000
Oct 28 17:08:36 BIGIP1500 Enabling the CPU’s according to the ACPI table
Oct 28 17:08:36 BIGIP1500 Intel MultiProcessor Specification v1.4
Oct 28 17:08:36 BIGIP1500 Virtual Wire compatibility mode.
Oct 28 17:08:36 BIGIP1500 OEM ID: OEM00000 Product ID: PROD00000000 APIC at: 0xFEE00000
Oct 28 17:08:36 BIGIP1500 I/O APIC 2 Version 17 at 0xFEC00000.
Oct 28 17:08:36 BIGIP1500 I/O APIC 3 Version 17 at 0xFEC10000.
Oct 28 17:08:36 BIGIP1500 Processors: 1
Oct 28 17:08:36 BIGIP1500 xAPIC support is present
Oct 28 17:08:36 BIGIP1500 Enabling APIC mode: Flat.Using 2 I/O APICs
Oct 28 17:08:36 BIGIP1500 Kernel command line: ro root=/dev/hda10 console=ttyS0,19200 panic=1 mem=224M platform=C36 quiet
Oct 28 17:08:36 BIGIP1500 mapped 4G/4G trampoline to fffd7000.
Oct 28 17:08:36 BIGIP1500 Detected 2500.180 MHz processor.
Oct 28 17:08:36 BIGIP1500 Console: colour VGA+ 80x25
Oct 28 17:08:36 BIGIP1500 Calibrating delay loop… 4993.84 BogoMIPS
Oct 28 17:08:36 BIGIP1500 Page-cache hash table entries: 65536 (order: 6, 256 KB)
Oct 28 17:08:36 BIGIP1500 Page-pin hash table entries: 16384 (order: 4, 64 KB)
Oct 28 17:08:36 BIGIP1500 Dentry cache hash table entries: 32768 (order: 6, 256 KB)
Oct 28 17:08:36 BIGIP1500 Inode cache hash table entries: 16384 (order: 5, 128 KB)
Oct 28 17:08:36 BIGIP1500 Buffer cache hash table entries: 16384 (order: 4, 64 KB)
Oct 28 17:08:36 BIGIP1500 POSIX conformance testing by UNIFIX
Oct 28 17:08:36 BIGIP1500 mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
Oct 28 17:08:36 BIGIP1500 mtrr: detected mtrr type: Intel
Oct 28 17:08:36 BIGIP1500 CPU0: Intel(R) Celeron(R) CPU 2.50GHz stepping 09
Oct 28 17:08:36 BIGIP1500 per-CPU timeslice cutoff: 365.65 usecs.
Oct 28 17:08:36 BIGIP1500 task migration cache decay timeout: 10 msecs.
Oct 28 17:08:36 BIGIP1500 enabled ExtINT on CPU0
Oct 28 17:08:36 BIGIP1500 ESR value before enabling vector: 00000000
Oct 28 17:08:36 BIGIP1500 ESR value after enabling vector: 00000000
Oct 28 17:08:36 BIGIP1500 ENABLING IO-APIC IRQs
Oct 28 17:08:36 BIGIP1500 Setting 2 in the phys_id_present_map
Oct 28 17:08:36 BIGIP1500 Setting 3 in the phys_id_present_map
Oct 28 17:08:36 BIGIP1500 Using local APIC timer interrupts.
Oct 28 17:08:36 BIGIP1500 calibrating APIC timer …
Oct 28 17:08:36 BIGIP1500 … CPU clock speed is 2500.2241 MHz.
Oct 28 17:08:36 BIGIP1500 … host bus clock speed is 100.0088 MHz.
Oct 28 17:08:36 BIGIP1500 cpu: 0, clocks: 1000088, slice: 500044
Oct 28 17:08:36 BIGIP1500 zapping low mappings.
Oct 28 17:08:36 BIGIP1500 Process timing init…done.
Oct 28 17:08:36 BIGIP1500 Starting migration thread for cpu 0
Oct 28 17:08:36 BIGIP1500 Transparent bridge - Intel Corp. 82801BA/CA/DB/EB PCI Bridge
Oct 28 17:08:36 BIGIP1500 Initializing RT netlink socket
Oct 28 17:08:36 BIGIP1500 Total HugeTLB memory allocated, 0
Oct 28 17:08:36 BIGIP1500 Starting kswapd
Oct 28 17:08:36 BIGIP1500 VFS: Disk quotas vdquot_6.5.1
Oct 28 17:08:36 BIGIP1500 aio_setup: num_physpages = 14336
Oct 28 17:08:36 BIGIP1500 aio_setup: sizeof(struct page) = 56
Oct 28 17:08:36 BIGIP1500 Hugetlbfs mounted.
Oct 28 17:08:36 BIGIP1500 pty: 2048 Unix98 ptys configured
Oct 28 17:08:36 BIGIP1500 RAMDISK driver initialized: 256 RAM disks of 4096K size 1024 blocksize
Oct 28 17:08:36 BIGIP1500 hda: HDS728080PLAT20, ATA DISK drive
Oct 28 17:08:36 BIGIP1500 blk: queue 02585e00, I/O limit 4095Mb (mask 0xffffffff)
Oct 28 17:08:36 BIGIP1500 ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Oct 28 17:08:36 BIGIP1500 hda: attached ide-disk driver.
Oct 28 17:08:36 BIGIP1500 hda: host protected area => 1
Oct 28 17:08:36 BIGIP1500 ip_tables: (C) 2000-2002 Netfilter core team
Oct 28 17:08:36 BIGIP1500 VFS: Mounted root (ext3 filesystem) readonly.
Oct 28 17:28:38 BIGIP1500 set_rtc_mmss: can’t update from 11 to 58
Oct 28 17:29:39 BIGIP1500 set_rtc_mmss: can’t update from 12 to 59
