Hello everyone, can anybody help me in resolving these errors.
i have recently upgraded F5 Big-Ip from 10.2 to 11.1 and recieving the following errors. 1. “Open ssl error -error:140790E5:SSL routines:SSL23 _WRITE:ssl handshake failure” (Navigating to System-->logs --> local traffic) 2. F5 big-IP is not sending all the logs to LOG Management system (Symantec SIM). Logs related to ASM are not present in the Symantec SIM, although i use to recieve the logs before the upgrade, F5 is only sending Partial logs to Symantec SIM, i can only view LTM Logs and some ASM LOGs which are of severity info,notice in Symantec SIM.
From the message one thing is clear due to the certificate miss match there is a handshake and trust problem with the pair device for any thing. Due to which the things are not working. Better that you open a case with F5 and do share with us your experience and resolution of this issue.
If you are using Server SSL profile and applied to the VIP, try changing the parent profile type to “serverssl-insecure-compatible” for the server profile.
same error, same version with client ssl profile. i try (as suggested) to set as parent profile “clientssl-insecure-compatible” but the errors are still present:
bigd is daemon which doing health check. so, have you checked https monitor e.g. missing certificate or key, certificate or key might not match, certificate or key might not be in pem format?
i deleted all custom ssl profile and ssl certificate (only default ones now is present) and i still have:
Jul 9 16:17:31 f5 err bigd[17045]: 01060111:3: Open SSL error - error:140790E5:SSL routines:SSL23_WRITE:ssl handshake failure.why is ssl profile?? i thought we were talking about https monitor, weren’t we?
Agreed. The fix for us was to remove the SSL health check one-by-one from each of the pools. We finally found one pool that was causing the issue. To be clear though, this is not a problem with the pool but rather a change in behavior on the F5 side from 10.x to 11.x. I still think F5 needs to fixed the issue or give the option to ignore untrusted certs for health checks (or whatever is the root cause of the error).
oh sorry…my misunderstanding becouse some research talk about ssl profile.
i’ve no custom https monitor. only the following default https monitors are present:
https HTTPS Common
https_443 HTTPS Common
https_head_f5 HTTPS Common
only https is used…
as soon i’ve deleted each use of that monitor for any pools, the error disappear…
