We currently have a BIG-IP 1500 GTM cluster and we would like to replace them with BIG-IP 2000. The current one is running on OS version 9.4.3 and the replacement one that we have received are on OS version 11.4.0. Could someone please suggest the procedure to follow for the replacement of the devices? I would like to keep the downtime as minimum as possible since there are loads of customers on these GTMs.
The number of changes between v9.4.3 (which is no longer under support by F5) and v11.4.x are massive.
If you want to keep your downtime to a minimum I would suggest a change freeze to allow you time to duplicate the configuration of your old box on the new one and then perform a hard cut. This would allow you to perform a quick back out if the upgrade does not go as planned to a known good device (what you are currently using).
The migration of the configuration from the old to the new is something that you will have to figure out since there are several ways to do it and it all depends on what you are comfortable with and allowed to do.
Good luck with your upgrade!
We have LTM 1500(10.2.2) and are moving to 4000’s, what is the best way to move the configuration over? We don’t have many VSs, so I was thinking about doing it via the gui. What about irules?
