F5 BIG IP and Airwatch SEG
I have an F5 Cluster (2X4K units). We are going to have an Airwatch SEG Cluster. I am wondering if anyone has an iApp template or if there was one created. If more information is needed let me know. Thank you!
More info will be needed.
What version of BigIP, What modules are enabled/licensed that you are wanting to leverage : LTM ? APM ?
What are you wanting to do with the Airwatch Secure Email Gateway ? - Load Balance Port 25 to a healthy server ? - Other ??
Version 11.5 LTM. No APM. And yes we would need to load balance port 25 from one healthy server to another. Version specifics below: GTM-DNS, Rate Limited, LO, BIG-IP(Perpetual) DNS Rate Fallback, 50 GTM Rate Fallback, 8 DNS Licensed Objects, 0 GTM Rate, 8 DNS Rate Limit, 50 QPS GTM Licensed Objects, 0 ` LTM, Base, 4000S(Perpetual)
`Application Acceleration Manager, Core
    IPV6 Gateway
    Rate Shaping
    Ram Cache
    Anti-Virus Checks
    Base Endpoint Security Checks
    Firewall Checks
    Network Access
    Secure Virtual Keyboard
    APM, Web Application
    Machine Certificate Checks
    Protected Workspace
    Remote Desktop
    App Tunnel
Hi Maybe try this one https://devcentral.f5.com/wiki/iApp.SMTP-iApp.ashx
With that said the config sounds pretty basic, ie Virtual, possibly SNAT, SMTP Port 25 Pool members with a SMTP heath check.
If the standard built in SMTP health checks dont suit your needs you could build a custom one, for eg: https://devcentral.f5.com/questions/custom-monitor-for-smtp-servers
Great thanks for the suggestions! Much appreciated!
