Dear All,
I have a problem with monitoring function pool in LTM module.
In command CLI , i can see tcp profile and gateway-icmp profile
In web GUI, i can’t see tcp profile, gateway-icmp profile and can’t assgin to pool
Please anyone can help me resolve this problem.
Thank you so much and have a good day.
Quynh Nguyen Duc
Best and Regards.
Interesting, Can’t you simple map the monitor to the pool from CLI itself. If on the CLI while trying to map it to the pool you can’t see that, it might make some sense.
Try that and update us too.
Hi jaikumar_f5
Thank for your response.
I have created test_tcp profile by CLI command ( can’t create tcp profile by web GUI )
And assgin test_tcp profile into pool by CLI command ( can’t assgin profile monitor to pool because it’s not shown on web GUI )
tcp profile not shown in web GUI
But in health monitors, it’s shown.
=> Works on CLI but web GUI doesn’t.
Anyone have idea help me fix this case.
Thank you so much.
I suspect it could be a possible bug. Can you please share your SW version.
My F5 BIG-IP 7600 is running version 14.1.2 Final 0.0.37
