F5 BIG-IP 10.1.0 TACACS authentication ACS 5.3 taking too long to login when first TACACS server is down
Hi All,
I am running the BIG-IP 10.1.0 LTM virtual edition and I have successfully configured it to authenticate against a couple of TACACS servers deployed in our Cisco ACSes 5.3.
When the primary TACACS server is up, all works perfect, GUI and console (tmsh) access. However, while doing some testing, I shutted down the primary TACACS server, and tried to authenticate the BIG-IP against the secondary TACACS server. This also works fine but takes between 3 to 4 minutes to grant access, which is of course excesive.
I ruled out as the cause of this issue the secondary TACACS server by configuring it as primary in the BIG-IP and everything worked pretty well.
Has anyone experienced this? If so, how did you fix it?
Thanks,
Alex.
Hi Alex,
May you can need your Help. i configured ACS 4.2 for LTM. but it not working with ACS 5.3 . how do we configure this. can you help in this.
In ACS 4.2 we give in PPP-IP tab and custome attribute. we define these . how we do in ACS 5.3
