Hi Guys,
Can you please share the method to automate F5 backup?
Thanks, Nilesh
Hi Guys,
Thanks, Nilesh
It depends on what you mean by automating a backup. Do you want to take UCS Backups? TXT File Backups?
CRON Jobs from a Linux Box Box can automate everything. Any major monitoring solutions can automate UCS and TXT File backups. BigIQ automates this process. Old EM still works and takes UCS backup Jobs.
It seems you are looking for configuration Backup,
Kindly find the below article as per your requirement
There is an iApp to setup auto backup that is worth looking at F5 iApp Automated Backup
Hi Den,
I looking for UCS backup. Can you please share the method to configure the same.
Thanks,
Hi Dali,
Thanks for sharing the useful article. In my case ssh is already configured so do I still require to generate crypto key and why do we require to generate it?
Thanks,
Check out GitHub for the latest version of the F5 Automated Backup iApp, and submit any bugs or questions as an “Issue” on GitHub:
