Hello iam using F5 version 12.1.3 and cannot find where to create ASM parent policy ??
yes, install a policy as a template and it appears in the list:
Select an existing Policy then save it at “save as Template”.
Then your template will be available when you will create a new policy.
you will have the possibility to select a template in Policy Template then “User-defined Template”.
let me know if you need more details.
regards,
Layered policies were released in v13. You’ll need to upgrade to use it. When you do, in the Configuration utility, create a new policy and then select “Parent” as the policy type. After the parent is created, any subsequent security policies can be children of that parent.
