The policy is set to blocking, i have set the parameter length to a max of 5 and is blocked when parameter length exceeds 5. However there is no blocking based on the meta characters, when I put value of ! or O in the parameter, there is no blocking and I cannot not understand why.
The configuration you highlight in the second screenshot is the parameter value not name. A parameter is a name/value pair. In this case name = id and value = something (but should block if you add a disallowed entry)
Sorry, i understand what you mean by value and name, i dont see “illegal meta character in value” only name option to block. Do you know where i can find it?
