Hi Team,
One of our customer is sending logs in a Specific timezone, in rt field of CEF logs we are getting the specific timezone logs. IS there a way to change the rt field to get the UTC logs or the epoch time in rt field.
Thanks,
Anshul
Hi Team,
Thanks,
Anshul
If you are able to modify how logs are sent or collected, you can perform the conversion at your collection tool or logging service to convert the RT field to UTC.
