Dear community,
I was wondering about the AS3 version currently used in order to deploy my AS3 on my BIG-IP target through BIG-IQ.
BIG-IQ should install this current AS3 version on F5 BIG-IP target when deploying AS3 declaration.
Checking on my BIG-IQ, 3.44.0
curl -sk -H “Content-Type: application/json” -H “X-F5-Auth-Token: $TOKEN” -X GET “https://$BIGIQ/mgmt/shared/appsvcs/info”
{“version”:“3.44.0”,“release”:“3”,“schemaCurrent":"3.44.0”,“schemaMinimum”:“3.0.0”}
Checking on my F5 BIG-IP, v 3.44.0
#pwd
/var/config/rest/iapps/f5-appsvcs
# cat version
3.44.0-3
My current AS3 declaration (I’m manually forcing schemaVersion) through BIG-IQ :
“class”: “AS3”,
“action”: “patch”,
"schemaVersion": “3.44.0”,
“patchBody”: [
“class”: “ADC”,
“schemaVersion”: “3.44.0”,
“target”: {
“address”: “X.X.X.X”
“op”: “add”,
“path”: “/Automation/APP_TEST_1.2.12.140_446”,
“value”: {
“class”: “Application”,
“remark”: “REFERENCE : NULL_REFERENCE_20241109215237”,
“schemaOverlay”: “AS3-F5-HTTPS-PASSTHROUGH-lb-template-big-iq”,
… etc }
Application Deployment logs from my BIG-IQ :
At the bottom : “schemaVersion”: “3.12.0”
I don’t understand why it’s using this older schemaVersion, it should use the current 3.44.0. Is there any policy on BIG-IQ that can enforce this weird behavior ?
“id”: “autogen_a4c95a0f-13e3-4078-92c3-3a8e6ea6f10c”,
“class”: “ADC”,
“controls”: {
“class”: “Controls”,
“userAgent”: “BIG-IQ/8.3 Configured by API”
“Automation”: {
“class”: “Tenant”,
“APP_TEST_1.2.12.140_446”: {
“template”: “tcp”,
“serviceMain”: {
“pool”: “/Automation/APP_TEST_1.2.12.140_446/HTTPS_443_pool”,
“class”: “Service_TCP”,
“enable”: true,
“profileTCP”: {
“use”: “/Automation/APP_TEST_1.2.12.140_446/HTTPS_443_tcp_profile”
“virtualPort”: 446,
“virtualAddresses”: [
“1.2.12.140”
“persistenceMethods”: [
“source-address”
“profileAnalyticsTcp”: {
“use”: “/Automation/APP_TEST_1.2.12.140_446/Analytics_TCP_Profile”
“HTTPS_443_pool”: {
“class”: “Pool”,
“members”: [
“adminState”: “enable”,
“shareNodes”: true,
“servicePort”: 443,
“serverAddresses”: [
“1.2.12.13”
“monitors”: [
“use”: “/Automation/APP_TEST_1.2.12.140_446/HTTPS_443_monitor”
“loadBalancingMode”: “least-connections-member”
“HTTPS_443_monitor”: {
“send”: “GET /\r\n”,
“class”: “Monitor”,
“receive”: “none”,
“targetPort”: 443,
“monitorType”: “http”,
“adaptiveWindow”: 180,
“adaptiveLimitMilliseconds”: 1000,
“adaptiveDivergencePercentage”: 100
“Analytics_TCP_Profile”: {
“class”: “Analytics_TCP_Profile”,
“collectCity”: false,
“collectRegion”: true,
“collectCountry”: true,
“collectNexthop”: false,
“collectPostCode”: false,
“collectContinent”: true,
“collectRemoteHostIp”: false,
“collectedByClientSide”: true,
“collectedByServerSide”: true,
“collectRemoteHostSubnet”: true
“HTTPS_443_tcp_profile”: {
“class”: “TCP_Profile”,
“synMaxRetrans”: 3,
“finWaitTimeout”: 5
“updateMode”: “selective”,
Thanks in advance for your help !
