As F5 SAML SP, is there a way in which APM will notify the user if the SAML AUTH failed? I have the SAML VPE below and seems that putting a message box after the SAML auth does not really help.
Sample VPE:
The question you asked is very good. I read it carefully but could not find anyone to help me understand it. Anyone can describe it correctly here https://community.f5.com/t5/technical-forum/f5-as-10eloto-saml-sp-with-azuread/td-p/294534
As F5 SAML SP, is there a way in which APM will notify the user if the SAML AUTH failed? I have the SAML VPE below and seems that putting a message box after the SAML auth does not really help. See https://community.f5.com/t5/technical-results-forum/f5-as-saml-sp-with-azuread/td-p/294534
