F5 Archiver Ansible Playbook
Problem this snippet solves:
Centralized scheduled archiving (backups) on F5 BIG-IP devices are a pain however, in the new world of Infrastructure as Code (IaC) and Super-NetOps tools like Ansible can provide the answer.
I have a playbook I have been working on to allow me to backup off box quickly, UCS files are saves to a folder names
tmp
under the local project folder, this can be changed by editing the following line in the
f5Archiver.yml
file:
dest: "tmp/{{ inventory_hostname }}-{{ date['stdout'] }}.ucs"
The playbook can be run from a laptop on demand or via some scheduler (like
cron
) or as part of a CI/CD pipelines.
How to use this snippet:
Gitlab: StrataLabs: AnsibleF5Archiver
Overview
This Ansible playbook takes a list of F5 devices from a
hosts
file located within the
inventory
directory, creates a UCS archive and copies locally into the ‘tmp’ direcotry.
Requirements
This Ansible playbook requires the following: * ansible >= 2.5 * python module f5-sdk * F5 BIG-IP running TMOS >= 12
Usage
Run using the
ansible-playbook
command using the inventory
-i
option to use the invertory directory instead of the default inventory host file.
NOTE: F5 username and password are not set in the playbook and so need to be passed into the playbook as extra variables using the
--extra-vars
option, the variables are
f5User
for the username and
f5Pwd
for the password. The below examples use the default
admin:admin
To check the playbook before using run the following commands
ansible-playbook -i inventory --extra-vars “f5User=admin f5Pwd=admin” f5Archiver.yml --syntax-check ansible-playbook -i inventory --extra-vars “f5User=admin f5Pwd=admin” f5Archiver.yml --check
Once happy run the following to execute the playbook
ansible-playbook -i inventory --extra-vars "f5User=admin f5Pwd=admin" f5Archiver.yml
Tested this on version:
12.1
This looks great but I’m coming across an error about 30 seconds or so into the creation task - “400 Unexpected Error: Bad Request for uri”. Further down the log I see “java.util.concurrent.TimeoutException”
The UCS gets created fine but it seems to be timing out. I’ve tried using async and checking the status of the job but that too produces the same error after around 15 (out of 30) checks.
Any idea what might be causing this?
