I am looking to understand if F5 Application Security Manager can replace the Data Power device in a network
IBM DataPower is a security device for SOA. Can F5 ASM meet all the requirements, which are met by DataPower?
Thanks in advance, Bindiya
Could you specify what your requirements are? These products can do many different things, so best to narrow it down to the exact functionality you are using the DataPower for and what you expect out of ASM.
Bindiya, I am working on a similar Project at this moment. Did you find something that Datapower does and ASM does not support?
