F5 appliance networking issue
.Basically I am trying to use latest Version 12.0.0 for experimenting TLS v1.2 ciphers, for that I downloaded version 12.0.0 OVF template and installed on my ESXI. I have configured 159 VLAN IP (10.80.159.240) for our management IP. All my applications are running on 160 VLAN. Following are the configuration i have done in My F5.
a) configured internal network configuration by adding 192.168.10.15 b) Configured external networking configuration by adding 10.80.160.43 c) added VLAN 160 in my VLAN list d) configured Nodes,Pools and VIP
But after adding I am not able to ping or access my VIP. Could you please guide me on this.
Thanks, Akhilesh
Are there any network diagram?
A few things to check. Is the VS listening on VLAN97, does the client traffic have a route to the VS via VLAN97 selfIP, does the F5 have a route to get to the client PC network, can the F5 ping the gateway router used for the client PC, can you ping VLAN 97 selfIP from the gateway router, can you ping the VS from the gateway router?
cheers
