F5 APM SSO for Webserver
Hi Guys,
I’m new to APM and we have a requirement for F5 to provide SSO when user is accessing the application as below.
Start--> Logon Page-->LDAP Auth-->SSO Credentials mapping-->Allow
Traffic Flow kicks in as below.
User Request F5 VIP Address/URL --> APM policy kick in and present login page ---> User type credentials and authenticated successfully, however SSO doesn’t get kicked in as expected, instead of SSO in the webserver, I’m getting prompted with webserver login page. Webserver uses same LDAP credentials to log in user to the server.
I’m unsure if I’m using the correct SSO credential mapping method. Currently I’m using form based SSO profile and I’m unsure about profile type and configuration I’ve used here. I have attached SSO profile I have configured here. I believe this is common setup so need to understand what I’m doing wrong here
Are you sure the Form Parameter for User Name and Password are correct (check the source of the SAP logon page) and is the form action correct?? The logon button is called Log On and you are using BOE/BI.
Cheers,
Kees
