F5 APM multi portal session limit
Sir, my customer would like to create multi portal for F5 APM. One for teacher access, another for student access. But customer want those portal have session limit. 100 session for teachers, 200 session for students.
How could I do ? User iRule? or Set Connection Limit in VS ?
Are the users using different VIPS for each portal (i.e. one VIP for teachers, one VIP for students)? If so, you could do connection limiting on the VIP.
otherwise, you might need to do it through an iRule. While I haven’t used either one of these, there are a couple iRule examples that can help get you started.
hope this helps
perhaps some more info then it doesn’t work would be useful.
personally i would build this with two virtual servers with different access profiles and configure a Max Concurrent Users per access profile (of 100 and 200).
[EDIT] didn’t notice the double topic with a similar answer.
