F5 APM Logging to Arcsight
can anyone please let us know whether APM uses CEF format as we are sending logs from APM to Arcsight and the logs are not getting parsed properly.
that depends on how you set up your logging, if you got through the publishers and destinations you are to able to say it is ArcSight.
As per v11.6, the information from the manualis:
Important: ArcSight formatting is only available for logs coming from Advanced Firewall Manager
(AFM), Application Security Manager™ (ASM), and the Secure Web Gateway component of Access
Policy Manager® (APM®). IPFIX is not available for Secure Web Gateway. Remote Syslog formatting
is the only type supported for logs coming from APM. The Splunk format is a predefined format of key
value pairs.
At the moment it’s not possible. I suggest you to open a case by F5 support. Maybe a RFE is existing and you can link your case to it or alternatively create a RFE.
hi amolari & boneyard, may I know what is RFE ?
An RFE is F5’s term for a “Request for Enhancement”. For APM, there is one that has already been created for ArcSight CEF formatting, 427106.
