F5 APM Lease Pool
Hi, Can we determine the IP lease time in APM Network access? My problem is that, our client connect VPN then they finish the connection. When they are connecting again, they should get same IP address.
Hi TayF5un
I have been looking for answer to similar query, but doesnt look like there isnt feature in APM. Moreover since ip is leased it forms tunnel with other end ip.
If someone has answer pls post.
