F5 and RTCP need help
hi all
i need you help in solving RTSP issue
LB : VS-A : xxx.xxx.xxx.xxx:554
Pool : Poolx
VS-B : xxx.xxx.xxx.xxx:0
Pool : Poolx
SNAT : xxx.xxx.xxx.xxx
: poolx-node-01 yyy.yyy.yyy.yyy
: poolx-node-02 yyy.yyy.yyy.yyy
proxyRTSP External : zzz.zzz.zzz.zzz:554
i set the persistence profile for VS-A and i can see the persistence record in status that request from Client goes to node-01.
but for udp RTP ( RTCP) i can see that the request if comming for both of the servers Node-A and Node B.
any help regarding RTP ( RTCP ) issue.
BR
sosa
Hello,
Can you post the full virtual server definitions (by running b virtual VIP_NAME list) and the persistence profile you’re testing with? Can you also list the persistence record(s) using ‘b persist all show all’?
You also might get more eyes on your post in the Adv Design and Config section (Click here).
Thanks,
Aaron
