F5 and airwatch SEG servers
Anyone out there setup a VIP for airwatch SEG servers? I currently have ours setup as a base https type setup. Not sure if that is the optimal way of doing so. Any suggestions are welcomed.
Thanks in advance.
You can define a Standard Virtual Server listening on https with a Pool forwarding traffic to the SEG servers. If you are doing certificate based authentication on SEGs, you have to define a PerformanceL4 Virtual Server and no SSL Profiles.
Alternatively, if you have F5 APM module, you can replace the SEG feature from Airwatch.
Best Regards
