F5 Analytics iApp - Mapping Regex
I’m trying to write a mapping regex for the F5 Analytics iApp (3.7.0). I’m struggling to find a regex combination that works with the naming convention used for the virtual servers.
Naming Convention
…vs
Example
app1.dev.443.vs
app1.dev.80.vs
app2.443.vs
I’m looking for a regex that will pare the virtual server name down to just the app name. Using regex101.com, I was able to verify this regex does what I want.
When I add it to the mapping table of the iApp, Splunk returns zero results. It seems either the iApp or TMOS itself does not honor the ? as it should. If I omit the ?, the iApp returns everything up to and including the .v of .vs instead of stopping at the first . after the app name.
Does anyone have any regex suggestions to just return the app name?
