I am testing Ai Gateway by looking at NGINX Modern Apps Docs. I have verified that OWASP LLM 01, 07 are working, but 02 Sensitive Information Configuration does not seem to be working. The demo video also contains Sensitive Information related content.
how config Sensitive Information masking for ai gateway?
AI Gateway Demo Video
The processor’s log looks like this:
{“time”:“2025-04-11T00:55:04.71766415Z”,“level”:“ERROR”,“msg”:“applying config to component failed, rolling back”,“error”:“failed to check processors: failed to fetch parameters for processor pii-redactor: unable to fetch parameters from url: http://aigw-processors-f5.devopschan.svc.cluster.local/api/v1/signature/f5/pii-redactor, got status: 404”}
2025/04/11 00:55:04 WARN will retry config apply in 5s (1 of 3)
{“time”:“2025-04-11T00:55:05.368088471Z”,“level”:“INFO”,“msg”:“successfully reported usage data”}
{“time”:“2025-04-11T00:55:09.767886333Z”,“level”:“ERROR”,“msg”:“applying config to component failed, rolling back”,“error”:“failed to check processors: failed to fetch parameters for processor pii-redactor: unable to fetch parameters from url: http://aigw-processors-f5.devopschan.svc.cluster.local/api/v1/signature/f5/pii-redactor, got status: 404”}
2025/04/11 00:55:09 WARN will retry config apply in 5s (2 of 3)
{“time”:“2025-04-11T00:55:14.817815787Z”,“level”:“ERROR”,“msg”:“applying config to component failed, rolling back”,“error”:“failed to check processors: failed to fetch parameters for processor pii-redactor: unable to fetch parameters from url: http://aigw-processors-f5.devopschan.svc.cluster.local/api/v1/signature/f5/pii-redactor, got status: 404”}
configuration file :
responseStages:
- name: protect
steps:
- name: pii-redactor
type: external
config:
endpoint: http://aigw-processors-f5.devopschan.svc.cluster.local
namespace: f5
version: 1
params:
threshold: 0.2 # Default 0.2
allow_rewrite: true # Default false
denyset: [“EMAIL”,“PHONE_NUMBER”,“STREETADDRESS”,“ZIPCODE”]
thank you.
