Hello everyone.
can anyone explain what does the 500GB/Month means, so each month the appliance it will delete the data or what ?
Best regards.
Sure. Within F5 Insight, we gather metrics, telemetry, configuration of BIG-IPs. As you know, a BIG-IP can emit lots of data, even more so with Insight (it does not use SNMP and we gather many more metrics over any competing solution). With that said, we review the data for statistical anomalies, quirks, and application configuration. If you forward some of the data to F5s AI Data Fabric, we take a deeper dive into the data and provide feedback e.g., security rating of applications, application workloads and more.
With all of that said, the 500GB number is the number of storage for roughly 50 BIG-IP instances. If you need or have more instances, the SKU quantity is increased. One SKU = 50 instances. So, we keep data for 30 days (roughly 500GB per 50 instances), analyze the data, review the data in our AIDF (if you turn it on) and provide feedback. As we start adding more things into our AI Data Fabric, on-prem RAG and LLM integrations, it’s the only way to put a hard stop on the number of metrics analyzed. Anyways, TLDR, 50 instances = One SKU = 500GB of storage you need for the telemetry inside your VM. Hit me up if you have anymore questions. Insight will collect data for 30 days and no more. You can export this data out to another tool that accepts oTel, or use the metrics proxy to collect the data and present it in another UI.
Ok Perfect, so 30 days that it’s mentioned in the SKU means the F5 insight he only saves the data for 30 days, so let’s say we are on day 33, so day1,2,3 will be wiped out right?
Also, the license determines the storage? let’s say I give 2 TB hard drive for the insight, so it will only use 500GB?
I’m glad to reply to me because I’m confusing!
Best regards.
Post 30 days we have a model based on fifo (some modifications). If you have a 2tb compute host, and only one SKU, you only get to use 500GB for insight.
