Hi Team,
We have installed F5 Management Pack (2.1.3) in our SCOM(2007 R2) server. After the installation we have discovered our F5 Device through SCOM(2007 R2) successfully . Now we can able to see all our nodes and Pools under Diagram View . We have Overide the F5 monitoring rules .
Now we are seeing “F5 Actions State” as Not Monitored . Kindly help what we have to do .
Thanks,
Raja S
Hi Raja,
I assume that the rule overrides may have not been set up correctly and this may have caused the F5 device health-model work-flows to stop working. Please make sure you follow the instructions on setting up the collection / threshold rule overrides described in this article: http://devcentral.f5.com/wiki/default.aspx/MgmtPack/PerformanceCollectionAndMonitoring.html
If your rules are set up correctly and you still get the error condition, please export and zip your override management pack and send it to us: managementpack(at)f5(dot)com. We’ll take a closer look and help you troubleshoot the problem.
Thank you.
Julian
