If we utilize any of the SFP 1.1-to-1.4 ports, can we still use the copper 1.1-to-1.4 ports?
Thank you.
ANSWER. The image posted was captured from a Visio stencil for the Big-IP 5x00. The actual Big-IP 5250v device shows the SPF ports labeled as 2.1 -to- 2.8.
Thanks.
Yes, you can use all ports and as you found the SFPs are 2.x labeled. Your SFP’s can even be used with fiber 10Gb, copper GBics or DACs(directly attached copper).
