does F5 4200v Support Virtualization ( VCMP ) Also does 5200v Support it ?
should be supported on 5200v, but not for 4200v.
Thx as i heared that 4200v has the letter āvā because it supports VCMP
as far as I know it was planned for the 4200v to support vCMP but F5 encountered problems with the chipset. It might be supported in the future
i figured the same 4200v would do virtualisation, but F5 is saying no at the moment.
