F5 13.1.1.2 & Grafana 5x - Dashboards not populating
Grafana is not populating the virtual servers, reverse engineered grafana datasource.js file & sent a REST call to F5 management interface to get the response on SOAP UI - passed in the correct headers & json request - Got an [] back for /mgmt/tm/util/admdb “utilCmdArgs”: "list-metrics /shared/admdb/default/vs -
{ “kind”: “tm:util:admdb:runstate”, “command”: “run”, “utilCmdArgs”: “list-metrics /shared/admdb/default/vs”, “commandResult”: “[]\n” }
but if I use other API’s for listing the virtual servers & stuff - i am able to get back expected results.
We followed the steps provided in GitHub - f5devcentral/f5-bados-app: F5 BIG-IP ASM DDOS Visualization application for grafana · GitHub and DevCentral - An F5 Technical Community - I have posted my questions there as well and to F5 support
Also, tmsh modify sys db admdb.debug.traffic.sample value enable doesnt work on 13.1.1.2. Any help is appreciated. TIA !
Similar problem here. No VSs showing. Running 13.1.1 for request {command: “run”, utilCmdArgs: “list-element “/shared/admdb/default/vs””} this answer {“kind”:“tm:util:admdb:runstate”,“command”:“run”,“utilCmdArgs”:“list-element \”/shared/admdb/default/vs\“”,“commandResult”:“ls: cannot access\n”}
Thanks Jiri - I did more poking around & found that some of the REST API calls are getting a valid response from F5. F5 support recommended that Behavioral DDoS is enabled to send data to Grafana - which we did & still dont see any data on Grafana. Question for you - was this working on previous F5 / Grafana versions for you or this is the first time that you are trying this out as well ?
Is there any update/solution ?
We have the same problem (TMOS 13.1.1.4 and Grafana 6.0.2). No VS is showing in Grafana. Message in Grafana:
“failed to list directory /shared/admdb/default/vs”
There is no /vs directory under /shared/admdb/default on BigIP.
Thx in advance.
Hi, very lucky. Just today I found the answer. You must use Evergreen version of the Grafana plugin. Here GitHub - f5devcentral/f5-bados-app at evergreen · GitHub
Yes, you will have to pull down the evergreen version from the repo GitHub - f5devcentral/f5-bados-app at evergreen · GitHub & you should be good.
Thx. Now it works…
