Hi, Is there a way to see which VIPS are using a particular SSL CERT from bigpipe(bp>) prompt or from bash. Just to add i’m unable to access tmsh as i’m directly getting bip pipe shell and able to go to the bash shell.
Thanks in advance!
Thanks in advance!
What version of code are you on?
The version is 9.4
Hi James, The system is on version 9.4.
Ok, so tmsh is not available to you.
I would think the only way would be to be in bash and write a script (bash, perl, etc..) that looks at the bigip.conf file and extracts the names of virtual servers which use a certain SSL profile. It wouldn’t be very easy, but that’s probably your best option.
It is not a native function of bigpipe
