We are using an external monitor on our F5 GTM (version 12.1.2) for sending curl statements to an openshift platform (https call constructed with DNS name & uri).
Up till now this seemed to be working.
But now for some applications hosted on this openshift platform , we are seeing strange behavior , when testing in CLI with curl statement like “curl -skv https://<application-name>/probe/liveness”
--> 2 out of 3 requests are coming back with “HTTP /1.1 200 ok” which is the expected answer
--> 1 out of 3 requests is coming back with 'HTTP /1.0 503 "
We also have some LTM units in same network & when doing the same request from LTM , we always get the “HTTP /1.1 200 ok” .
So the behavior seems only to be present on GTM , not LTM units.
When diving into SSL answers which are failing we mainly notice :
* server is presenting different certificates (failing call is using different certificate than the ones that are working)
* failing calls we see answer coming back in http /1.0 and giving a 503 response (rather than answering in 1.1
My main problem is that we are only seeing this kind of behavior on GTM . We never have this behavior on LTM units & even tested from other stations .bit here we are always getting the correct answer .
