External antivirus with ICAP compatibility matrix
Hello,
I’ve been searching for a compatibility matrix between F5 BIG-IP versions and external antivirus products with ICAP but the only information I’ve managed to find is that BIG-IP is using ICAP version 1.0, is that the only requirements that I need to check before implementing a new external antivirus with ICAP ?
We’re currently using an old version of Symantec Scan Engine with a BIG-IP 11.6 and we’re planning to upgrade both product to latest version, so the target is Symantec Protection Engine 8.2 with BIG-IP 16.x, can anyone confirm that both product will be compatible ?
Thank you
Frederick
