Exporting iapp template from BIG-IP 11.2.1 Build 862.0 Hotfix HF2 and importing to BIG-IP 11.2.1 Build 1104.0 Hotfix HF4 fails
Trying to get a copy of iapp template f5.http_solar_alpha.2012_08_09 from Production F5 to Development F5. It fails whether exporting to a file and then importing, or copying and pasting text. These are the errors which all seem to stem from the file f5.http_solar_alpha.2012_08_09.cli_script not being found. I am no longer able to find this template and I don’t recall how I installed it originally. Just looking for some clues as to what to try next.
line 4 [script “f5.http_solar_alpha.2012_08_09.cli_script” included from “APP_TMPL_/Common/f5.http_solar_alpha.2012_08_09_definition” not found][tmsh::include “f5.http_solar_alpha.2012_08_09.cli_script”]
line 230 [“\r” has no meaning. Did you mean “\r” or “r”?][{\r\n}] line 230 [“\n” has no meaning. Did you mean “\n” or “n”?][{\r\n}]
line 231 [script “f5.http_solar_alpha.2012_08_09.cli_script” included from “APP_TMPL_/Common/f5.http_solar_alpha.2012_08_09_definition” not found][tmsh::run_proc f5.http_solar_alpha.2012_08_09.cli_script:do_tmsh_create “\”$component\“” “\”$arguments\“”]
line 255 [“\r” has no meaning. Did you mean “\r” or “r”?][{\r\n}]
line 255 [“\n” has no meaning. Did you mean “\n” or “n”?][{\r\n}]
line 256 [script “f5.http_solar_alpha.2012_08_09.cli_script” included from “APP_TMPL_/Common/f5.http_solar_alpha.2012_08_09_definition” not found][tmsh::run_proc f5.h Unexpected Error: Loading configuration process failed.
Line 4, 231 and 256: If you can’t find the f5.http_solar_alpha.2012_08_09.cli_script then you really have an issue, any idea what was in it? You could always try and create a blank or dummy file with the correct name in the relevant directory perhaps?
Line 230 and 255: It looks like some escaping is required, \r\n or “\r\n” perhaps?
The template you refer to is still posted on DevCentral along with its associated CLI script. See DevCentral - An F5 Technical Community with the link “New HTTP (alpha)”
Additionally, I have just posted “HTTP backport.” This is the latest HTTP template being prepared for v11.5, modified so that it runs on v11.2.
Thanks for all your assistance. I was able to upload the original f5.http_solar_alpha.2012_08_09 template from the devcentral website as Fred suggested. I will try out the HTTP backport template also. Thank you for the tips.
