Exempt http to https url redirection for specific IP addresses in Irule
Hello,
I have a VIP with with address 10.20.20.20 which configured to use SSL. http to https redirection also configured on the F5 so that users will be redirected to if they access http.
now I want to bypass the http redirection for some users with specefic IP addresses (Means users with ip address 10.55.22.22 should access http url and should not use SSL). I have an Irule for this but it is not working. Can anyone help me with this.
    if { [IP::addr [IP::client_addr] eq 10.55.22.22] }
      return
       do nothing
    else {
    HTTP::redirect https://[HTTP::host][HTTP::uri] }
-Jinshu
Are you using route domains? You may need to string the RD off of the client_addr.
    if { [IP::addr [getfield [IP::client_addr] "%" 1] equals 10.55.22.22] } {
        return
        do nothing
    else {
Hi, i think you have to configure 2 VS. One for SSL and one for http. Then you can configure your rule to the VS for http. Regards
I have separate VIP for 80 and 443. I have applied the irule on 80 vip only but it is not working. I am getting page cannot be displayed.
Is there a default pool configured on your VIP 80 ? Try this:
when HTTP_REQUEST { if { [IP::addr [IP::client_addr] eq 10.55.22.22] } { pool my_pool_for_http } else { HTTP::redirect https://[HTTP::host][HTTP::uri] } }
