Exclude specific cookie from set_cookie_header iRule
We currently apply “Secure” and “HttpOnly” via the iRule below. We now need to exclude any cookie that starts with “XSRF-TOKEN” from the “HttpOnly” portion of this iRule. Any help in syntax would be appreciated!
when HTTP_RESPONSE { set unsafe_cookie_headers [HTTP::header values “Set-Cookie”] HTTP::header remove “Set-Cookie” foreach set_cookie_header $unsafe_cookie_headers { HTTP::header insert “Set-Cookie” “${set_cookie_header}; Secure; HttpOnly” } }
Try this… HTTP::cookie secure should return “enable” if it’s been set according to the Wiki but I’ve not tested the output myself
  set unsafe_cookie_headers [HTTP::header values "Set-Cookie"]
  if { not ([string tolower [HTTP::cookie value]] starts_with "XSRF-TOKEN") && ([HTTP::cookie secure] eq "enable" )} {
    HTTP::header remove "Set-Cookie"
        HTTP::header insert "Set-Cookie" "${set_cookie_header}; Secure; HttpOnly"
        return
Thank you again for your assistance, very much appreciated!! We were able to get it to work with a few tweaks.
    if { $set_cookie_header starts_with "XSRF-TOKEN"} then {
        HTTP::header insert "Set-Cookie" "${set_cookie_header}; Secure"
Pleased you got it working and thanks for sharing the final solution. :slight_smile:
MP
