Exclude servers from SNAT automap
Hello, I have a question regarding excluding 2 servers from a snat automap. The BIG-IP has SNAT automap set, and a forwarding virtual server to make sure the servers behind the BIG-IP find their appropriate outbound route.
I need to find a way to exclude these two servers from being SNAT’d. All of the other servers (which there are many) still need to be SNAT’d.
I cant find a way to exclude these 2 servers from being SNAT’d. It seems that with a global SNAT automap, you cannot explicity exclude IPs from the SNAT. When you create the SNAT you can explicitly include IPs, but not exclude.
I wrote an iRule for the forwarding virtual server to try and exclude these servers from being SNAT’d, however that does not seem to have an effect, as the SNAT that is doing the SNATting is a global SNAT.
What are my options here?
TIA
Are the servers you’re trying to exclude sending traffic outbound and that’s where you’d like to prevent them from being SNATed? Or are they receiving inbound traffic and when they’re selected, you’d like to keep the traffic from being SNATed on the way to them?
This’ll be a pretty easy rule…just curious as to your traffic direction.
Hi cerpika,
Here are two ways to do the same thing. If you need more than two addresses or so, I’d recommend consolidating them into a datagroup for ease of manageability.
Example 1:
when LB_SELECTED {
if { [[IP::server_addr] != 10.0.0.1] or [[IP::server_addr] != 10.0.0.2] } {
snat automap
Example 2:
when LB_SELECTED {
switch -glob [IP::server_addr] {
10.0.0.1 -
10.0.0.2 { }
default {
snat automap
Hope this helps,
George
Interesting. I would have gone with the snat none approach. I wonder if there is a performance hit for snat automap called in an iRule versus applied as profile in the virtual?
Good question Jason. I guess the opposite approach with the same functionality would be to turn on snat automap in the profile and then just say:
when LB_SELECTED {
    10.0.0.1 -
    10.0.0.2 {
      snat none
Same thing, really, but I wonder if there’s a performance difference. To the test-cave!
Colin
Each of these examples assumes he’s SNATing inbound traffic üòõ
Since he mentioned both an IP_Forwarder and outbound routes, I’m assuming this is going to be an outbound SNAT…stealing Colin’s example.
when CLIENT_ACCEPTED {
  switch -glob [IP::client_addr] {
    10.0.0.1 -
    10.0.0.2 {
      snat none
Curse you, details, you elude me yet again!!!11
:stuck_out_tongue:
No seriously though, good catch.
Colin
