Exchange issues after F5 Failover testing
Hello All,
I have facing very critical issue at user level, after I perform F5 failover testing on Sunday.
I have topology like below.
2 DC = DC1 and DC2
each DC have 2 nexus 5548 and F5 6900 is connected to each Nexus switch at both the DC’s.
so F5_1 at DC1 is connected to core1 and core2 and F5_2 at DC2 is connected to core1 and core2.
now we have layer 3 VLAN configured on Nexus and the IP of that L3 vlan is configured in failover pool on F5 to detect failure of device.
during failover testing, I just SHUT L3 vlan on Nexus core1 and Core2 at DC1 and failover happened to F5_2 of DC2, however I did not disconnected physical interfaces of F5_1 connected on core switches of DC1.
after failover I found some of the application stopped working and errors on HPOV showing no routes to HOST, as I had shutted L3 interface and I am having static routes configured on nexus to reach any VIP go to floating IP of F5 which is of same VLAN of which L3 i made down.
Does this can be the cause why i experienced failure. what is the correct method to test failover of F5 in live enviornment. I just wanted to be sure if DC1 goes down everything will work via DC2 as both F5 are in cluster.
Later I did rollback, but on Monday users started experiencing issue on the exchange. Some sessions was not working, after following steps some sessions started working.
1. Reboot of desktop/laptop
2. IP change of desktop
3. Reboot of HUB/CAS servers on both DC’s
4. : Free-Busy information of users in DC1 is not available for user in DC2 when trying to invite them for a meeting
Can some one suggest if this issue is related ot persistence? we have configured Source Add aff persistence on F5 for this VIP.
Here I found the cause of impact.
can someone explain me why connection is different from 2 servers of same location (DC2) to connection of VIP at DC1
working server
VIRTUAL 10.155.65.45:https ↔ NODE 10.155.54.159:https TYPE any 1/0
CLIENTSIDE 10.155.55.143:48278 ↔ 10.155.65.45:https
(pkts,bits) in = (107, 119194) out = (65, 15252)
SERVERSIDE 10.155.70.156:48278 ↔ 10.155.54.159:https
(pkts,bits) in = (65, 15252) out = (103, 119034)
PROTOCOL tcp UNIT 1 IDLE 60 (3600) LASTHOP INTERCO 54:7f:ee:5f:a9:bc
Non-working server
VIRTUAL 10.155.65.45:https ↔ NODE 10.155.55.146:https TYPE any 1/0
CLIENTSIDE 10.155.55.146:40256 ↔ 10.155.65.45:https
(pkts,bits) in = (47788, 60.15M) out = (26866, 3.158M)
SERVERSIDE 10.155.70.157:40256 ↔ 10.155.55.146:https
(pkts,bits) in = (24713, 3.072M) out = (43749, 59.99M)
PROTOCOL tcp UNIT 1 IDLE 3 (3600) LASTHOP INTERCO 54:7f:ee:5f:a9:bc
