Hi, i pretty new to F5 and liking what i see but have a slight problem on realtion to users connections on when we fail over the backend mailbox servers. We have 2 CAS servers in a casarray which all traffic come throught the Ext and internal F5 Virtual load balancers, however the issues are premerly which internal connections on the internal Load balancer.
We have a one rule setup for the casarray :-
iRule to select pool and persistence method when all Exchange
Client Access services are accessed through the same BIG-IP
virtual server.
switch -glob [HTTP::path] {
“/Microsoft-Server-ActiveSync*” {
Direct all ActiveSync clients to a common pool; use
HTTP cookie persistence
persist cookie
pool Exchange_2010_CAS_single_as_pool
HTTP::class disable
“/rpc/rpcproxy.dll” {
Grab all requests for Outlook Anywhere; the following
checks assign correct persistence methods.
switch -glob [HTTP::header “User-Agent”] {
“MSRPC” {
This User-Agent section matches most versions of
Outlook and Windows using Outlook Anywhere.
The OutlookSession cookie is new to Outlook 2010.
if { [HTTP::cookie exists “OutlookSession”] } {
persist uie [HTTP::header “OutlookSession”] 3600
else {
persist uie [HTTP::header “Authorization”] 3600
“*Microsoft Office*” {
This section matches some versions of
Outlook 2007 on Windows XP
default {
This section catches all other requests for
Outlook Anywhere, and sets a persistence method
that does not require the client to support
HTTP cookies
persist source_addr
Finally, this assigns the Outlook Anywhere pool and turns
off full HTTP parsing and compression. If the preceding
clients should be sent to separate pools, the pool statement
should be removed here, and a separate pool statement
placed in each of the preceding logic branches.
Other modules (APM, ASM, etc.) should be disabled here
as well, if active for other traffic though this virtual
server.
pool Exchange_2010_CAS_single_oa_pool
HTTP::disable
COMPRESS::disable
HTTP::class disable
“/xml/autodiscover.aspx” {
Requests for Autodiscovery information. The selected pool
might be unique, or might be the same as e.g. your pool
for OWA or ActiveSync. In this example, we use the same
pool that receives ActiveSync traffic.
persist cookie
pool Exchange_2010_CAS_single_ad_pool
HTTP::class disable
default {
This final section takes all traffic that has not
otherwise been accounted for and sends it to the
pool for Outlook Web App
persist cookie
pool Exchange_2010_CAS_single_owa_pool
If using the Web Accelerator module, uncomment the
following line and change the name to that of
your WA class.
HTTP::class select Exchange_2010_CAS_single_wa_http_class
But when we fail over to another mailbox server there is a delay for reconnects, we are using onconnect profiles but not SNAT??? and also we have aBES server and 6 months ago i had to change the time out on each persistant uie rule from 7200 to 3600??? would the time have anything to do with client re-connects taking so long to reconnect to another mailbox server???
I ran a few test on realtion to the outlook client and i added a in my local host file the ip address to one cas server… and it worked fine.. but whe i changed back to the casarray VIP address on the internal LB - it toom arounf 10 minutes to reconnect???
ITs not a major issue, but if anyone can spot a mistake on the irule of know of this issue i would be so gratefull ![]()
Huwster ![]()
