Hello, Needing recommendations to create an application Health Monitor for MS Exchange 2010.
Currently I have two pool members health check monitor is https(443), I know I can use SMTP, but Exchange engineers say thats not good enough.
They want and application layer monitor, they tell me that when they are updating IIS it stops the email function on the node. They want it to be marked down. I said I can use SMTP, but they say nope, need something at the application layer to monitor exchange.
I have no idea what they are asking for, to me SMTP should be fine, other than that, what else can I use?
A similar situation arose here and the solution was to let the folks who run exchange decide from themselves - simply by using a RECV string on the https monitor. Fetch, say, /status.html and check for ‘Service is up’. Then the application folks can decide whenever they want a node removed from service by changing the string - no guesswork on the F5 side and they are feeling empowered by having control over availability.
Hi all, I created the advanced health monitor on the deplyment guide, but don’t seem to be working. The Node always stays up using this monitor. Even if I use a fake login name and password or create an error on the Send Sting. I’m using a https parent. I really could use help on this, of cource the exchange engineers are playing the blame game, because the F5 didn’t do what they expected. Issue is they never asked for this, they only asked for smtp and https monitors. Its always the networks fault…below is what I have.. Any idea?
sorry to not explain it well. the send string you use is to request form based login page. authentication is not needed to retrieve the login page (i.e. user and password do not matter). the health monitor will mark pool member up if the response contains “OutlookSession=”.
if you want health monitor which also does user authentication, you may have to find another url.
Ok, it seems the exchange engineers what to use User Login function for use with a Advanced Health Monitor for Exchange 2010. I used the outlook deployment guide, but its not working. It always shows up even it I error out the user name…Sure could use some help.
Ok, it seems the exchange engineers want to use User Login function for an Advanced Health Monitor with Exchange 2010. I used the outlook deployment guide, but its not working. It always shows up even it I error out the user name…Sure could use some help.
it seems the exchange engineers want to use User Login function for an Advanced Health Monitor with Exchange 2010. I used the outlook deployment guide, but its not working. It always shows up even it I error out the user name…Sure could use some help.what authentication are you using? if it is basic or windows integrated authentication, you can use “outlook web app advanced monitor” health monitor in deployment guide page 73 as Regan suggested (i.e. GET /owa/\r\n and 200 OK).
if you are using forms-based authentication, the monitor in the deployment guide cannot be used because it does not do user authentication. the following is old thread about exchange 2007.
how to add owa form-based monitor for Exchange 2007
i did a bit modify jjh’s script as below. the “replace_with_username” and “replace_with_password” in the script need to be replaced. anyway, i am not familiar with exchange, so the script may not be fully correct and customization may be required.
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm monitor external owa_mon
ltm monitor external owa_mon {
defaults-from external
destination *:*
interval 5
run /Common/curl_adex2
time-until-up 0
timeout 16
user-defined HOST owa.f5.com
user-defined RECV "Deleted Items"
user-defined URI1 /owa/auth/logon.aspx\?url=https://owa.f5.com/owa/&reason=0
user-defined URI2 /owa/auth.owa
[root@ve11a:Active:Changes Pending] external_monitor_d cat \:Common\:curl_adex2_14
!/bin/sh
(c) Copyright 1996-2007 F5 Networks, Inc.
This software is confidential and may contain trade secrets that are the
property of F5 Networks, Inc. No part of the software may be disclosed
to other parties without the express written consent of F5 Networks, Inc.
It is against the law to copy the software. No part of the software may
be reproduced, transmitted, or distributed in any form or by any means,
electronic or mechanical, including photocopying, recording, or information
storage and retrieval systems, for any purpose without the express written
permission of F5 Networks, Inc. Our services are only available for legal
users of the program, for instance in the event that we extend our services
by offering the updating of files via the Internet.
@() $Id: http_monitor_cURL+GET,v 1.0 2007/06/28 16:10:15 deb Exp $
(based on sample_monitor,v 1.3 2005/02/04 18:47:17 saxon)
these arguments supplied automatically for all external monitors:
$1 = IP (IPv6 notation. IPv4 addresses are passed in the form
::ffff:w.x.y.z
where "w.x.y.z" is the IPv4 address)
$2 = port (decimal, host byte order)
Additional command line arguments ($3 and higher) may be specified in the monitor template
This example does not expect any additional command line arguments
Name/Value pairs may also be specified in the monitor template
This example expects the following Name/Vaule pairs:
URI1 = the URI to request from the server to get OutlookSession cookie
URI2 = the URI to request from the server to authenticate user
RECV = the expected response (not case sensitive)
HOST = the FQDN name
remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
IP=`echo ${1} | sed 's/::ffff://'`
PORT=${2}
PIDFILE="/var/run/`basename ${0}`.${IP}_${PORT}.pid"
kill of the last instance of this monitor if hung and log current pid
if [ -f $PIDFILE ]
then
kill -9 `cat $PIDFILE` > /dev/null 2>&1
fi
echo "$$" > $PIDFILE
send request & check for expected response
curl -fNs --connect-timeout 5 -k "https://${IP}:${PORT}${URI1}" -H "Host: ${HOST}" -c /var/tmp/cookies.txt > /dev/null
curl -fNs --connect-timeout 5 -k -L -d "destination=https%3A%2F%2F${HOST}%2Fowa%2F&flags=0&forcedownlevel=0&trusted=0&username=replace_with_username&password=replace_with_password&isUtf8=1" -b /var/tmp/cookies.txt -b "PBack=0" "https://${IP}:${PORT}${URI2}" -H "Host: ${HOST}" | grep "${RECV}" 2>&1 > /dev/null
mark node UP if expected response was received
if [ $? -eq 0 ]
then
echo "UP"
fi
rm -f $PIDFILE
exit
by the way, have you used http analyzer tool such as httpwatch, httpfox? i think it is very helpful in buliding http monitor.
HttpFox: The Firefox add-on you can’t live without by Lori MacVittie
Hi, I have the same isssue here. When the exchanges guys stop the exchange process, the monitors for OWA and active sync keep green. The cause is that the IIS webserver keeps serving it login screen, even if the exchange process died.
We used the latest iapp for exchange on V11, iapp 1.2.
