Exchange 2013 OWA using iApp template
I am just beginning my Exchange 2013 migration project and I have my servers built and I am wanting to put the CAS servers behind my LTM. Running 11.3. I have installed the latest template and have answered all the question to deploy the template. However, when I try to access my Exchange 2013 OWA page I get “The connection to the server was reset while the page was loading.The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.” I can access my CAS servers individually just not using the F5 pool.
Hi, which browser are you using? Does it happen in all browsers? Are you offloading SSL, or bridging? If you’re offloading, did you configure the CAS to not require SSL?
I have used both Firefox and IE. Reading your suggestions I have re-deployed the template making sure I set the SSL offloading and configured CAS to not require SSL. I am getting the OWA page now, so thank you for that. I am getting a different issue now that may not be F5 related. Now when I am prompted for the login/password at the OWA screen it comes right back to the login screen.
Update, I am able to log in to OWA if I disable one of the nodes.
Do you have the same cert configured for IIS on all of your CAS?
I thought I had, but I must have missed it on one of them. It is now working with both servers enabled in the pool. Thank you for pointing me in the right direction.
