Is it possible to configure the Exchange 2010 CAS iApp to get this result?
- Client sends SSL traffic to LTM;
- LTM redirects SSL traffic to CAS nodes (without decrypting it).
That is, I don’t want the LTM to terminate SSL connections, but I don’t want to send unencrypted traffic to the LTM. I just want the LTM to load balance the encrypted sessions.
The options in the iApp seem to assume that either SSL connections will be terminated at the LTM (and then re-encrypted back to the CAS node, or not), or traffic to the LTM won’t be encrypted in the first place. Am I missing something obvious, or does the unencrypted form of the requests need to be accessible to the LTM for the iApp to be worth using?
Thanks.
